Yes, if you already have what you need with Brazed Carbide that will work fine. If you have AL and AR style tools as well, that should get you up to the shoulder on the front and back section as well. If you have boring bars, then sounds like you are all set. Good luck! Be sure to post a pic of your finished part.All that makes sense. I presume a D or E style tool which I own (attached) could do the chamfering in lieu of the CCMT tool.
The final question would be how to face and chamfer the ID where the parting took place.
That looks like it is working. Looks great. Could maybe even go a little narrower on that hose bead on the end. Maybe see how hard it is to get the hose on? Although if a match to your drawing then I am sure it is good. Just looks wide in the pics.Good practice. Clearance is really tight by the bead. View attachment 361839
Would think just one tool swap. From the bevel tool to the turning to the shoulder tool. And yes, par for the course with tool swaps.I think the feature is wide, I based it off the size of the barb on the radiator outlet but that formed sheet metal with continuous curvature so not exactly the same. Getting the 26mm portion machined felt like a lot of improvisation and swapping tooling around. Is that just par for the course?
