- Feb 1, 2018
- 1,868
It looks as if it needs some diagonal supports like RJ suggests. Thanks for the new pictures. I thought those rubber pads were wheels. I have seen those rubber pads have issues in the past. Your pucks look good, but the the ones you buy are rated for PSI - I would take some test cuts and see what happens . That's a light machine and it may be fine. I always say better safe then sorry and over doing it is better...lol.. It just seems like more support on the base would be better. I like the jam nut levelers, might add some lock washers under the bottom lock nuts. I would not use plywood. You can buy a butcher block wood table top and use that if you want it sitting on wood. Plywood's name "PLY" means bend.
It is wonderful to see your "love" for the machine to make it right and share here with word and pictures.. A great example to the new Hobbyists who read the forum. Thank You!
