- Nov 16, 2012
- 5,596
Rich,
I think this is what you might be talking about. See this post: http://www.hobby-machinist.com/showthread.php/10476-Triangular-Leveling-Base If this is not the correct concept you were talking about then please say so, so I don't misguide folks.
I built these because the edges of my garage floor are sloped a good inch at the sides (presumably for water runoff). These mounts worked very well for me to get the base close to being leveled. I ended-up building a heavy duty bench and moving it further back from the wall where the floor was not so horribly sloped.
Ray
Ray
You can solve the problem of the sloped floor by using 3 points under the cabinet (Kinematic mount principal). Many machine tools sit on 3 points to eliminate twists. In a shop I am rebuilding a grinder at has issues with a rough floor, so they used leather super glued to steel plates so the plate would not slip, if you want to spend some money you can buy wedge leveling mounts (http://www.reidsupply.com/products/leveling-devices-vibration-control/machinery-leveling-mounts/) . Place them under the lathe cabinet; put 2 under the head-stock end and one under the end of the Tail-stock end.
Moparfever for your information I am a Journeyman Machine Tool Rebuilder, have been aligning and leveling lathes for over 40 years, I manufacture machine levels and teach way scraping and rebuilding / building and have probably rebuild or helped build new machines, (a good guess would be) 1000 lathes and level aligned 5000 lathes in my career. Turning a test bar is the easiest way and most precise method as it duplicates the actual cut you're making when it's being used. (even if the ways are worn) to do this with and with-out a level!. Like I said before, I'm trying to help you with proven methods and not guesses. If you want to experiment to satisfy your curiosity go for it, but don't tell someone it won't work as I know it will !!. I was taught this method when I was an apprentice and it works. Many new machine builders tell their customers to use it for the final test after leveling. I can send you a pdf on how to do it if you PM me your Email Address. I can also send you the info we use to align tail-stocks and turrets.
