I have some time on the Al Bino belt. I really want to like it, but.... This is the only lathe I have ever run, so perhaps my expectations are incorrect. I have to tension it more than I think is good - I have read that too tight is hard on bearings, and it is certainly tighter than the Logan manual recommends. It has to essentially be taut to not slip, and even then the maximum depth of cut I can take in steel is .020 off the diameter. More and the belt will slip (the auto serpentine I had on for a while would let me take .060 or so before the lathe slowed, but I don't think that was belt slip, just not enough power, that made me nervous). . Then I made the mistake of remembering to put oil in the middle drive cone pulley oil hole, the one with the screw. Whenever I do that, most of the oil comes back out the screw threads when the lathe runs. It got on the belt and the lathe wouldn't run at all. After much scrubbing of the pulleys and the belt with acetone, it runs again, but noticeably worse. Now, to get .020 off diameter in steel, I have to tension the belt very tight - the belt cover starts to raise up a bit with the tension. It takes forever for the lathe to spool up to speed, especially on the fastest speed. I suppose that is good to an extent, in case of a crash it will slip and not damage gears. Is that all to be expected?
