Hy guys.
Thank you for answering.
Will i talk about some stuf i am moving around for 20 years.
When i saw lathe cnc lathe i was stuned. And i wont to own one.
But here is a snag.
if i buy old manual one, it is all worn, ways are worn, gears have spacing betwen them, oil leks everywere and so on. There is no spere parts. This is a real problem. I like manual lathe it is a charm and magic in them. But you will not earn living with it. and be fair. This wil hurt realy hurt. Old machinery had realy good grey cast iron. I am disapointed that we live in now, and we cant make beter cast iron as 50 years ago. Rigidity of machine is les cast iron is **** and so on. I know of one lathe on witch you can remove and put on new ways. It is lathe Potisje from Prvomajska and it has difrent types as 30B, 22 and so on. Ways are tempered put on lathe and whole lathe is then put on big macine where they grind it scrape it and this is it.
As buying seling is concerned. Peopel buy lathe work on it and seel forward, when you see that you need to reper it and repair cost more as you can make from it. It is the same in cnc world. If i buy weiler for exsample i need to pay 50% of price then loading and shiping costs. This is usaly al together 2.5X price of lathe on seling inetrnet store auction stuf. IF you buy center lathe, usaly it is robed of everthing, colets, chuck, axsesories. You got what cant be removed from lathe. I am loking now two nice lathes, but on them is so meny things mising it is horable. Then you ened to repair it this is one year job at earliest. Cost is betwen 3K euro to 48.000 euro schaublin 150 rebuild for exsample. If you buy cnc for i dont know 20.000 you have old destroyed cnc lathe and you need to scrap al electrical systems, paint and so on. You need to repaint it, put ney linear gudes and so on it and ney cnc system. But it is doable. I am not afraid of this. It is exspencive but you will have nice lathe. Center lathe are modified cut in some places you canot weld cast iron, i have one exsample of this at home.
So what to do?
If i buy manual lathe it need to be without gears, if you wona put on servo motor you canot go this with 6000 rpm on gears. Then problem is with ways, you need to repair them. But soon or later you need to rebuild ways witchis costly, linear guide ways you yust change and this is it.
It woud be nice to make one lathe plans for a lot of people and this is it.
So if i took sheet metal and weld it, yes it wil warp, but,... weldment can be thrown in fire and strees relived, yes?
But here is a snag. Steel vibrates, as i read. So this is the reason for gray cast iron. But Polimere concrete is much better option, as vibration is concerned.
If you build metal weldment. I think gray cast iron cant be welded, yes? And then put gray cast iron bed from old lathe witch wass milled on miling machine so you cut of the ways, so you can put on linear rails, wudnt this be an option? Question is "will miled bed warp becose you miled ways away?". THis we shoud ask some guy who know. Or put on it polimer concrete bed.
Then you buy linear rails and ballscrews, put in on.
There i sproblem with the spindle, you need spindle build from schrach.
If i look at repering old center lathe, this is a disaster. Okisidised nuts, and bolts, dirty oil stains like glue, previus modification reapairs on komponents, ways repair, worn gears and pinions, removing paint, repaint it. I was there do this,... .
I realy dont know what is beter option. Build from schratch or repair old center lathe. And when you are done. What you have. On center lathe you have 8 to 12 rpm values with determined feeds in two directions. As cuting feeds and speeds is concern is a litle triky. Ok you need to use hss toling witch is cheper. But, if you build one cnc from schrach you ahve veristiltiy of speed and feed, positioning on psindle and option to use hss or carbide. And you can run more identical parts easily, for exsample.
And remember, new lathes, have bad gray cast iron, you dont repair this kind of lathe machine, you buy another one. Potisje and prvomajska didnt have good cast iron. But wiser, schaublin, willer and other german lathes for exsample had dem. Even french, british and so on had beter cast iron. If you buy china, you buy good exspencive lathe it will last, if you buy you know what it will not last. I talked to owner who had one he said that lathe bed is twisted becose of torsion forces, and all lathe is squiling when he try to cut 1mm of ordinary steel.
There are two problems. How to build lathe bed and spindle this is it. I loked on intenret and i didnt foudn nobady to sell this both things., You can get old lathe sfor cheap. Old releve gray cast iron bed. I woud love to know if we mill that bed it will perform
. Probbaly you will tel me i am stupid to even think about it.
. That it is sin to cut gray cast iron lathe bed. Idotn kare, i have one laying around, and it is realy good gray cast iron, but you know what. Al other parts are sh.t. I throw it in the scrapyard and get 40 euros for it or i mill it.
Thank you for your opinions, aprovals, disaprovals, hard core teroretical and practical opinions and fact. I relay love to talk and brainstorm this topic.
Some pricing:
tnp 160 lathe 3000 to 7000 euro (14 000 euro totaly rebuild one)
tnp 245 lathe 2000 to 5000 euro
wiler comodore lathe 3000 to 10 000 euro
potisje lathe 4500 to 8000 euro (18 000 totaly rebuild one)
emco v 10 1000 to 2800 euro
wagner lathe new best quality as otehr 8000 firly big lathe will not bend bed torzionaly with hard use even after 5 years (they tested it)
schaublin dont tuch it from 15 000 to 20 000 euro (totaly rebuild 35 000 to 48 000 euro)
schaublin 125 cnc 12 000 euro around here somere
Have a nice day.
