Lathe - Barber Shop Pole Pattern, Loose Carraige?
Don't guess, get back out the the shop and get out the indicator. Something is up! :)
The first lathe I got up and running just would never cut. I got another lathe :D :D :D
Check headstock/bed bolts
Camlock connection
Make sure jaw caps are tight and not bell mouthed
Gibs tight and ways oiled
With the belts/spindle drive disengaged, do you feel any knocking or roughness when you turn the spindle by hand?
Already check spindle end play, .001 and tightened the bearings to remove. Chuck is a brand new PBA 8" monster. With the belts/spindle drive disengaged its smooth as silk.
Did you try turning between centers? Tightening the tailstock will eliminate and endplay as a test.
Did you try a different chuck? An out of balance chuck can cause strange patterns. Just my 2 cents. bob
Have you tried hand feeding? Remove the leadscrew (or power feed screw, if they are not both built into one) from the equation. Disengage the drivetrain if you can when hand feeding.
