- Dec 8, 2013
- 2,651
You'd just have to limit your depth of cut and feed per tooth appropriately. After all, flycutters work.I have seen end mills that size used on 50,000 lb mills with 50 HP spindles. The problem is the amount of twisting force it applies to the machine. I get nervous when using a 3/4 x 4 inch end mill on my 3,500 lb machine. It is not heavy enough to overcome the cutting forces imposed by the cutter when using that end mill to capacity. With a 2 x 10 inch inch end mill, the amount of stick out would be huge and the twisting torque applied to the head would be immense.
And don't climb mill.
