With nothing else better to do with $15, I picked up a 2" x 10" end mill. Its about the size of a brick (except for being cylinder shaped ). 6 flutes, and new (still in the waxy coating). OK, it's too big for my BP J-head. I thought about making a 2" to 1/2" adapter, and use it in an R8 in the BP, and on the Lathe (largest drill bit I have is 1 & 7/8", so 2" end mill would get me to 2" ID on tasks before I have to start using a boring bar). I assume when its worn out I can grind it and use it for HSS (not sure how to clamp it in the QCTP unless I ground it down significantly or made yet another adapter).
Any other thoughts on what it could be used for?
Thanks
Thanks
