Over the weekend, I made a 9 hour one way trek to buy a SB9A Just getting it cleaned up a little. It has a catalog number of 544-R which is the 4 1/2 foot bed with 8 speed V- Belt drive.
I also ran it in all 8 speeds and with the cross feed, longitudinal feed and thread feed, and everything seemed to run nicely Got it moved to position and will let it sit overnight before I try to level it. It is now about .010" out of level (twist). I do want to get turning on it.
It came with a taper attachment, QCTP, 3-jaw chuck, face plate, lathe dogs , live center and other stuff in the pictures.
Before I turn on it, I want to find out as much as possible about this lathe, and I want to make sure my spindle is getting oiled. In the pictures, you will see the oil cups. I topped them off with some 20w non-detergent oil, and they seem to use very little oil. How long does the oil stay in the cup when they are lubricating properly? In other words, how would I know if the bearings are getting enough oil. Also, there are 2 holes right above the oil cups; are these breather holes or what?
I do plan on making a new pulley tightening rod, eventually.
I'm sure I will have more questions, later.
