- Feb 21, 2022
- 772
Set the tool with the spindle off.That is a neat trick, I have a 6” scale and will try it out. Does 500rpm sound reasonable?
Haha, yes indeed.Set the tool with the spindle off.
It's all part of the learning process. Remember it, so you can help someone out in the future.So, maybe I should post this in the goofs and blunders thread…
I bought a tool set from LMS, and I thought I was using the threading tool. But it’s not close to 60 degrees:
So I went back to the kit and found this:
I will try this one and report back.
Getting there. Yep, stick out really is a thing. For relatively thin stock, you're better off with only 3x the diameter sticking out. That and low depth cuts. This will reduce the deflection. Another thing to try are spring passes. That's when you repeat the cut at the same depth. It helps to get the cut more uniform.Better. The stick out is getting me now, there's a .007 difference in diameter at the outer end vs an inch in
