- Nov 25, 2015
- 8,301
The hinge on mine is bolt on both sides with a plastic insert for the sheet metal, and a hair clip (I think that's what it's called).When adding anything to the hood watch the weight. It puts more stress on the hinges and can cause problems. You likely will add lights to the hood but just be careful about too much weight. Open and close carefully
and I have welded up my hood from rust, and also riveted it up.
