- Jul 2, 2014
- 7,594
Auto speedometers are inherently inaccurate. They rely on the tire diameter being constant, which it never is. Also, a new set of tires will be a different diameter. Then they ran it through a cable to a drum with a magnetic follower, which has no inherent accuracy. Yes, they were calibrated, and still are, but they become inaccurate immediately, the calibration is just a useful talking point in court.Old car speedometers could be accurate, if they tried. Witness the police certified units. But most were made to budget with aesthetics a primary factor. It's hard to be accurate when your entire range is covered in 60-90 degrees of sweep.
I'll put up a picture of the tach I found in the barn this evening. Accurate or not, it is an impressive piece.
