    Dismiss Notice
I got me one of these! HASLER SPEED INDICATOR
Discussion in 'TOOL JUNKIES - TOOLS & TOOLING (Love Tools? This Is Your Forum)' started by Finster, Apr 18, 2017.
  1. Bob Korves
    Bob Korves H-M Supporter - Premium Content H-M Supporter-Premium
    2,668
    113
    USA
    City:
    Sacramento
    State:
    California
    -Return to Top-
    Auto speedometers are inherently inaccurate. They rely on the tire diameter being constant, which it never is. Also, a new set of tires will be a different diameter. Then they ran it through a cable to a drum with a magnetic follower, which has no inherent accuracy. Yes, they were calibrated, and still are, but they become inaccurate immediately, the calibration is just a useful talking point in court.
    RJSakowski likes this.
  2. woochucker
    woochucker United States Active Member Active Member
    172
    43
    City:
    Pittstown
    State:
    New Jersey
    -Return to Top-
    Go get Aluminum Tape in the HVAC area in the HD, or LOWES. Used for sealing insulated air ducts.
    I use it for a lot of things. It's durable, reflective, and hold tenaciously, but can be peeled because it's AL, not paper
    4gsr likes this.
  3. Finster
    Finster United States Active Member Active Member
    226
    43
    City:
    Fredonia
    State:
    Pennsylvania
    -Return to Top-
    Well, I just got this thing in the mail. It's SUPER NICE! :D I mean, it doesn't hardly look like it has ever been used. The case doesn't even have a scuff on it and the felt lining is perfect. The device doesn't have a scratch and the rubber wheels are even in great shape! I would have to say that this is pretty much mint! I got all excited, read the instructions, ran out to the shop, chucked up a piece of round bar and tried it out. It worked flawlessly! :grin big: Now I don't know how accurate it is. I'll have to compare it to another device or something known but so far I'm really happy with it. It's super simple to use also. Now my only question is, it has a small oil hole on the shaft. I'm wondering what type of oil to use? Maybe just a drop of 3 in 1 ?
  4. Tony Wells
    Tony Wells United States Vice President Staff Member Administrator
    19,208
    113
    Tyler, Texas
    City:
    Tyler
    State:
    Texas
    -Return to Top-
    It's just called "Strobe Tachometer". I run it on an old iPhone. It was free in the app store.
  5. rgray
    rgray Active User H-M Supporter-Premium
    251
    83
    City:
    Helena
    State:
    Montana
    -Return to Top-
    My vote would be spindle oil. Like Mobil velocite #6 . But that's cause I have it for the mill and cylindrical grinder. Very thin.
  6. grzdomagala
    grzdomagala Austria Iron Registered Member
    9
    3
    City:
    Wien
    State:
    Outside US / Canada
    -Return to Top-
    Update. Just checked the meter with LED driven from impuls generator - at 50Hz it shows 2960rpm and at 500Hz 29768rpm. Quite accurate. I also tested it at 6.5V supply voltage (dead battery simulation) - still the same, correct values. Looks like my diy meter is the bad one.
    Quite impressive for 10$ meter...
    Wysłane z mojego GT-N7100 przy użyciu Tapatalka
  7. RandyWilson
    RandyWilson United States H-M Supporter - Premium Content H-M Supporter-Premium
    44
    18
    City:
    Chesapeake
    State:
    Virginia
    -Return to Top-
    I was talking about the potential of the instrument itself. Yes, the drive mechanism was suspect. Still is.
    This is the one I found in the barn, ex Father in law. It is truely a tachometer; readings in real time. IMAG0380.jpg
  8. kd4gij
    kd4gij United States Active User Active Member
    878
    113
    City:
    St. Petersburg
    State:
    Florida
    -Return to Top-
  9. Finster
    226
    43
    City:
    Fredonia
    State:
    Pennsylvania
    -Return to Top-
    Well, I chucked up a piece of round stock on the lathe and drilled a center hole for testing this. The free app I downloaded on the phone was placing surface speed of the .750 round bar at 580 rpm. My antique Swiss timepiece was put in the center hole and measured 590 rpm. Now I don't know the math to figure it out (I'm sure someone here does) but I do know that the center will be spinning faster. That being said, it seems pretty good to me and as accurate as I need. If anyone can figure out the equation and see if they match, I would be interested, just for kicks. All in all, I think I scored pretty good. However, I hope it doesn't break, I doubt anyone could fix it and I believe the company finally went out of business in the 80's Not to big of a deal. I'll probably check all my belt settings on my machines, write it all down and it will sit in the drawer for the most part. Nice to have though.
  10. RandyWilson
    44
    18
    City:
    Chesapeake
    State:
    Virginia
    -Return to Top-
    RPM is RPM, no matter the diameter. You have agreement within 2%, which I would think is close enough for spindle speeds.
    RandyM and uncle harry like this.
  11. Finster
    226
    43
    City:
    Fredonia
    State:
    Pennsylvania
    -Return to Top-
    Why is that not sounding correct? I'm not arguing, just confused. I'll have to think about this for awhile. The strobe, by nature, is checking the mark on the outside of the bar. So, in essence it is actually checking surface speed, correct? The other is checking the center of the bar or "the shaft" of say a motor. Why do I think they should not be the same? By the way, I flunked algebra more than once.
  12. Tony Wells
    19,208
    113
    Tyler, Texas
    City:
    Tyler
    State:
    Texas
    -Return to Top-
    The timing mark is going to appear in the strobe just once per revolution, no matter what size the OD is. It doesn't take any longer to swing around the axis of rotation no matter what size it is. I think you are trying to integrate surface speed into this, but that is another thing altogether. That is diameter dependent. But put that out of your thinking on this one. 1 inch, 100 inches or 100 miles......how long it takes to complete a single rotation is the basis for how this works. The actual time it takes for that revolution does affect surface speed, but not RPM.
  13. Finster
    226
    43
    City:
    Fredonia
    State:
    Pennsylvania
    -Return to Top-
    OK that helped and I agree. But now I have a different problem. (look at the picture of my first post) I use one of the little wheels and put it on the surface. My RPM is way off, not even close, off by more than a thousand. I put the pointed center in, take a reading in the center drill hole and it's dead nuts. Why is that?
  14. RandyWilson
    44
    18
    City:
    Chesapeake
    State:
    Virginia
    -Return to Top-
    By using the rubber wheel against the surface, you are incorporating surface speed into the equation. The ratio would be your stock diameter divided by the wheel diameter. A 1/4" rubber wheel against a 3/4" piece of stock will give a reading three times faster than expected.
  15. Finster
    226
    43
    City:
    Fredonia
    State:
    Pennsylvania
    -Return to Top-
    Humph. Learned something new. Retaining it will be the problem. ;)
    Strangerthings169b1 likes this.
  16. Finster
    226
    43
    City:
    Fredonia
    State:
    Pennsylvania
    -Return to Top-
    Thanks for the help and info everyone.
  17. Ken from ontario
    Ken from ontario Canada Active Member Active Member
    143
    43
    City:
    Peterborough
    State:
    Ontario
    -Return to Top-
    You won't regret buying that tach(the one in Bob's link), I have that model and it gives consistent readings , in my opinion this is one Chinese product that could easily cost more and people would still find it a good deal.
    ch2co, uncle harry and Bob Korves like this.
  18. Jericho
    Jericho United States Active User Active Member
    1
    16
    City:
    Kimball
    State:
    Tennessee
    -Return to Top-
    You got a smart phone for less than $10. Now THAT was a bargain. :big grin:
    uncle harry likes this.
  19. benmychree
    benmychree United States Active User H-M Supporter-Premium
    74
    28
    City:
    Saint Helena
    State:
    California
    -Return to Top-
    Actually, this type of device operates by counting turns on the dial in a given period of time; I have a similar device and that is how it works. Read the instructions on the card on the back of the case, it spells out the operating mode. When you engage the button, you can hear the clock mechanism inside ticking; when it stops ticking, it disengages a clutch on the input shaft.
    Bob Korves likes this.
  20. ch2co
    ch2co United States Grumpy Old Man H-M Supporter-Premium
    345
    63
    Mile High Colorado
    City:
    Center of Colorado 5362ft
    State:
    Colorado
    -Return to Top-
    My only problem with the el cheapo tach I got off of eBay is that it uses a 9 volt battery. I hate 9 volt batteries. My tach has a habit of not turning itself off
    and 9 volt batteries are just too darn expensive to keep replacing every time I don't bother to turn it off.:guilty: Otherwise that little guy is my goto tach.
    The mechanical tach is beautiful to behold, but is difficult to use for determining the speed of your chuck for instance. I really like my Machtach
    on my lathe. All three of my tachometers read within a couple of percent of each other.
    rgray likes this.
  21. Bob Korves
    2,668
    113
    USA
    City:
    Sacramento
    State:
    California
    -Return to Top-
    I have lots of things that take batteries, but I leave the batteries out of them until I am ready to use them, and then remove the batteries immediately afterward -- with a few exceptions. A flashlight for when the power goes off, a couple wall clocks, and my daily user HF digital calipers.
  22. ch2co
    345
    63
    Mile High Colorado
    City:
    State:
    Colorado
    -Return to Top-
    I just pulled my old mechanical tach out from under a pile of more often used tools, and it is a Misawa Seiki brand, Japanese. Its from the mid 60's.
    Doesn't need any instructions since even I figured it out how to run it, although the instructions are clearly printed in the top of the box, if you read
    Japanese. Although the photo makes it look round, the outer edge is polygonal just like Finster's Hasler. See below:
    And to answer to Bob, I try to remember to take the batteries out, but being senile as I am, (just ask the wife) I sometimes forgets.
    There's nothing worse than to open a battery compartment and find it filled with white crystalline powder and the contacts all
    chewed up.:(
  23. Dave 41
    Dave 41 United States Iron Registered Member
    0
    1
    City:
    Florence
    State:
    Mississippi
    -Return to Top-
    QUOTE="RJSakowski, post: 478973, member: 36675"]And then it was sent on to Japan and the Japanese tapped the hole.[/QUOTE]
    The way I heard it: The Swiss sent it back to the Germans who proclaimed themselves the winner of the competition since the Swiss returned the wire unchanged. The Swiss replied that the Germans were wrong, and they would have known that if they had examined the wire more closely. The Swiss cut the wire in two, and turned the end of one piece down and threaded it. The remaining half was bored and internally threaded, and the two pieces were screwed together.
  24. uncle harry
    uncle harry United States Active User Active Member
    267
    63
    City:
    Big Bend
    State:
    Wisconsin
    -Return to Top-
    The way I heard it: The Swiss sent it back to the Germans who proclaimed themselves the winner of the competition since the Swiss returned the wire unchanged. The Swiss replied that the Germans were wrong, and they would have known that if they had examined the wire more closely. The Swiss cut the wire in two, and turned the end of one piece down and threaded it. The remaining half was bored and internally threaded, and the two pieces were screwed together.[/QUOTE]
    I've heard the first version of this series of micro machining, but threading and tapping at that level might just require some historical investigation.
Share This Page
