Keep checking Craigslist.
That is where I found this one.
The last one, I paid a little more than I wanted but it's in nice shape too. (The other 042, Not the long Pattern makers)
The pattern makers needed more work than he let on, (E bay seller) so we worked out a partial refund deal, where I was happier.
I had to glue down the veneer in several spots, and I thought it would lay down nice, but after clamping, I had some raised sections, where I was forced to sand.
So then I was worried I was going to cut through the veneer, But I was good, ...........LOL..........Or lucky really, and was able to level it nicely with out cutting through.
I do have a few minor minor spots where I would like a little filler, but I loaned my filler to someone, and when I got it back, (bet you thought I was gonna say I never got it back)
I put it in a different place. So now I can't find it. What is your favorite filler, I forget what this last tube was, but it seemed to work OK.
A lot of times it would dry up before I used hardly any of it, but this tube seemed to hang in there,. As you can see, I took the handle off to make it easier to sand and apply the finish.
EDIT
If you click on the picture, and click on it again, then click on that one again, It "blows it up" pretty good, you can see 3 small spots. (This in in Firefox, I am guessing other browsers are the same)
They were holes drilled in there, I don't know why. (I knew about them before I got it)
What I did there was glued in pieces of a tooth pick ,(the round kind) and sanded flush.
Hopefully it won't be too noticeable.
