- Aug 2, 2020
- 565
The fact that you would return used lumber back to Home Depot says a lot about you.
Here is the contrivance I rigged up on the loader forks to set the trusses on my garage.
I returned these beams too.
Looks like they would have made a great gantry for inside the shop....Here is the contrivance I rigged up on the loader forks to set the trusses on my garage.
Uh, People that return stuff after USING it chap my HIDE! I don't think you got the Gist.Here is the contrivance I rigged up on the loader forks to set the trusses on my garage.
Here is another little project I did.The fact that you would return used lumber back to Home Depot says a lot about you.
You might be surprised I agree with you. It is clear that you have great ingenuity.A man can do a lot if he puts his mind to it - and is not afraid...
However advice to a novice needs to be tempered - you don't know what the OP's abilities and experience.
I have no doubt you or I could do the OP's thing. The trick is how to advise a novice what to do safely with unknown experience.
We have all shaved the 4X thing. I just said it was good practice. Often I lift using 10X safety factor. Comes from 20 years as a Rope Rescue Instructor.Lastly, you may not approve but the strap I used was not rated for 4X the weight.
Also remember the Harbor Freight load rating system is very accurate. If something is rated for 1,000 lbs, then it will fail at precisely 1,000 lbs. Remember, in China, they read right to left, so to arrive at that rating system is purely logical, but we think differently in the west and assume that the capacity is the safe handling capacity. It surely isn't.The engine hoist's highest rating is rated when the extensions are all the way in for the legs and the lift, Pulling them out reduces capacity substantially.
