- Feb 25, 2021
- 3,130
Another similar approach, if you have two matching size angle plates, you can check them against each other on a surface plate to see that they add to 180. Then check both of them using a squareness indicator to see if they are both equal. If both conditions are true to within whatever tolerance you use for your checks, than your angle plates are 90.It is possible to check a 1/2/3 or 2/4/6 block for squareness. The sum of the four included angles are equal to exactly 360º. A squareness indicator as used by TOT referenced in post #4 above normally has to be zeroed with a known good reference square.
