- May 16, 2016
- 1,700
I learned how to do silver brazing buying a MAPP/Oxy torch and by having done 10,000* hours of solder and silver soldering. (*) only a slight exaggeration.
I learned how to use a lathe by truing commutators on my Taig micro-lathe.
I learned how to use a band saw by having spent thousands of hours using cross-cut/bow/coping/hack saws.
I learned how to use a mill by buying/using a mill until the parts coming out bore some resemblance to what I was trying to make.
I still watch videos of guy who are actually good at machining.
There is no substitute for doing, As the saying goes, practice makes perfect. of course your question relates to where do you get the original instruction for the first step ,and the second step, then the third step, etc etc,.
You can always ask questions here on this forum and get many wise answers. Although I was formally trained as a fitter & Turner / Toolmaker many years ago, I will be the first to insist that there is no single right way to do anything. There are a few methods that are not recommended, usually because they are dangerous, but generally if it works and is not dangerous then it's a valid process. The one thing I will always come down on is climb milling , except for light finishing cuts, It has the potential to damage your machine and you, and will often damage the part you are working on.
There are members here who have had no formal training that often produce excellent work on complex jobs and by going about in a way that many would say is wrong. Bit if no damage has been done then is it wrong?
