- Feb 8, 2014
- 492
Looks like a TRACTOR SUPPLY tank. I have one for argon and one for mixed gasThat's an owners tank, cool and exchangeable....
Kinda doubt it but will check.Looks like a TRACTOR SUPPLY tank. I have one for argon and one for mixed gas
Being an Everlast clone isn't really a good thing. I have a LONG history with Everlast, and it's not good. My first inverter machine was an Everlast. Within weeks it developed a problem and it took over 50 (yes, I have them saved) e-mail, multiple phone calls and at least five tries sending me parts before they offered to either replace it or give me full purchase price credit towards a more expensive machine. Heck, twice they sent me parts for the wrong machine and this was a brand new machine. It wasn't until I got on the phone with Oleg (the owner) and pushed a bit that things got resolved.Yeah, not many reviews yet. One said it’s “Basically an everlast clone”
Who knows if that’s correct but we all know how things work in Shenzhen….
John
I'd skip the AHP. AHP is owned by the same folks as Everlast and they're out of the same building with one suite being Everlast and the other AHP. Going off memory it's Oleg's wife (he started Everlast) who is listed as the head of AHP. They're known to have even slightly slower customer service than Everlast...which is saying something. You can do a search on their address and then use Google maps to get a street view of the facility and it seems certain it's essentially the same company with two suites in the same building.John: I don't have a tig yet but the AHP and the Primeweld are both on my list
I can't believe how many cheap inverter welders there are now- probably junk for the most part and little to no support
Disposable goods
Take me to the pilot (or landfill)
There's more to it than just having the correct pin configuration, so there's no way of knowing if that would actually work with your machines. I doubt it, but the manual might specify pedal requirements.I like the looks of this Eastwood, and the price is low compared to others.
Eastwood TIG 200 AC/DC Foot Pedal (20565)
Replacement Foot Pedal for Eastwood TIG 200 AC/DC Welder (20565)www.eastwood.com
John
Thanks for the feedback, I figured there was a reason that used red or blue pedals were selling for $$$ on eBay.There's more to it than just having the correct pin configuration, so there's no way of knowing if that would actually work with your machines. I doubt it, but the manual might specify pedal requirements.
Quite honestly, the pedals with a dial adjustment on them are largely junk and cheap foot pedals are incredibly annoying. The kind specified for your welder is the old tall box style that means you'll have your foot perched up in the air. The old Miller boxes were like that and I can't stand them...no way to get comfortable. I've put SSC controls foot pedals on both my TIG welders and it's a huge upgrade. Many companies are copying that style pedal (lower, wider, more stable)...worth the upgrade if you can find one to work with your machine.
Hopefully you got a flow meter, not an actual regulator. For MIG a regulator with two gauges is fine...one is pressure and the other flow. For TIG it's a lot better to get a flow meter with one round gauge and a vertical tube with floating ball that indicates the flow rate. The other thing to check is the delivery pressure the flow meter provides. Most of the inexpensive flow meters (and regulators) are set to provide 50PSI, which is fine for MIG, but for TIG when you hit the pedal you get a blast of 50PSI gas that's annoying, and wastes gas. 20-25PSI flow meters are a lot nicer to use, save gas, and don't have to be expensive. I've put about 20 of these on welders in the past couple of years....inexpensive, but work pretty well.
