Do you own a 3d printer, or have a friend who does? I can model a gear stl file for you in about half a minute.
A 3d printed gear won't last forever and isn't the strongest option, but it's advantage is that you can print as many as you need. If you learn CAD, you can print them in any possible tooth count for pennies in material, and consider them disposable.
Here is a .stl file for a 45t module 1.5, 20* PA, gear. I gave it a 16.25mm bore with a 5.2mm keyway, to allow some sliding clearance, and allow for the tendency of most off the shelf, not-fine-tuned 3d printers to print holes a little undersize.
I modeled one in Alibre Design and am printing it, just to see how it turns out. If you don't have access to a 3d printer, I can mail this gear to you if you need.
the STL file is attached.
Edited to add: For anyone who doesn't have access to CAD or is otherwise unable to model their own gear design, there are online gear generators that will generate a .stl for you. Just input the necessary information. Just make sure to account for sliding clearance in the bore and keyway size. I think (could be wrong) that the G4003 and G4003G both use a 1.5 module, 20*PA. In the generator link below, gear length is the gears thickness.
The Free STL Gear Designer For 3D Printing
www.stlgears.com
