Height Adjustable Stand
Let’s look at the back side of the socket weld to see what kind of penetration I got:
I am not so impressed with this penetration.
Here is the .082” or so tubing (main mast/outside tube) on the 1/2” plate.
3 autogenous tack welds, 1 regular tack weld, 360° around autogenous (skipping around), lay wire technique with 3/32” filler rod (not skipping around), & the weld did not need washing.
150A max & usually using all of it.
See undercut in tubing, third picture down. Can you say stress riser?
