- Aug 1, 2022
- 137
When I bought my Heavy 10, it came with a lever drawbar system that was missing the sleeve and collets.
Since I brought the lathe home, I spent my time renovating it with a full disassembly, cleaning and installation of new felt.
I’m finally at the point to where I can can work on the collet system that came with it. No sooner than placing the order for a 5C sleeve (that was obviously missing), that I realized that I should’ve try mounting it to see if it’ll even fit my 10L first (I know… should have done this first). I jumped the gun because I assumed that the previous owner used the collet system with this lathe.
After trying to mount it, I’m pretty sure my lever drawbar isn’t the correct one for the 10L.
The only labeling on it just states “Big Mac Fullerton, CA, Mack Manes Enterprises, Inc.”.
The drawbar tube measures 22-1/4” (seemingly way too long). The tube appears to be the right diameter though.
I took it all apart and cleaned it up. I pressed the tube out and I think i can at least cut it down to make it fit. So I’m trying to find more info on the specs for the correct 5C system for my 10L, whether it be the lever or hand-wheel type, or whether I’m missing any additional parts. The drawbar tube also can’t be inserted until it’s flush with the left side of the spindle (the cover hits).
I’m thinking I can probably cut the tube down and machine the shoulder part to press the tube into it, in order to make a hand-wheel drawbar.
I found an old listing for a hand-wheel drawbar that supposedly has a p/n of HW-102 with a 11.5” tube length. Trying to confirm this.
Here are pics of what I have.
Meanwhile, the 5C sleeve is shipping and I’ll get it sometime next week.
Any videos on how to setup/use both types of drawbars?
Thanks.
Thanks.
