Note to self, check lathe carriage for 'stink bugs', the brown variety that we have here in East TN in abundance.
Was turning and threading some 1" aluminum tube to 7/8-32. (No relation to Wreck™Wreck's post above
On the second skim pass on the threading operation to verify it, the half-nut did not disengage and my reflexes
were not quick enough to hit the BIG RED stop button.
There was a large nest of the bugs up in the carriage. So bad that their carcasses in the upper portion of the half-nut
assembly had prevented the slide from retracting and disengaging.
At the end of the crash the face of the 3-jaws were jammed nice and tight against the AXA holder, the piece was
mangled and the bit was buried deep into the 1" portion of stock.
Thankfully, due to dumb luck or maybe an over worked guardian angel, the chuck didn't collide hard with the compound.
It did mess up the shaft on the quick-change gears, had to dis-assemble and de-burr.
The half-nut assembly still isn't right, so I guess I'll be doing a carriage tear down.
Also I'm now threading using the
inverted bit, threading away from the chuck, method.
