Golf cart to atv.
Dang man I forgot to get them pics. If you need them still let me know. I did talk to the neighbor but he only has electric crap that he aint using. And a couple complete gassers
I don't need the pic's now that I got this. I am looking for the 3" drop spindles from the Jakes kit for 91 to 01.5. just the spindles.
Man they aint cheap for what they are. Can you weld? Aint hard to make a spindle so long as you aint getting alot of travel. Hell even if you are. Truth be told, if the spindle aint built to the tire height and rim off set, it's just a spindle. I have designed and built mid travel front ends. King pin, caster, camber, camber gains, bump steer, all that good stuff.
I dont weld. Wish I could. Man if I lived alittle closer I would get you to help me out.
Well that cart is comming slow. I have the coil spring rend mounted to the leaf springs. Now need to come up with a way to mount the motor so it moves with the rearend
Got the motor blocked up now for suports.
Well the motor mount is all welded to the rear end. the drive belt will be here thursday. going to have to build a custom exhaust for it
Well the motor is in just have to work out the throtle cable now.
Depending on the differential gear ratio, it should really move!
GG
Well had it running today. Now just need to rig up a throttle cable and take it for a ride. Then I can start on the lift kit.
Well the accelerator and choke cables are riged up. I pickup a fuel tank tommarow and take it for a test drive.
