- Nov 22, 2022
- 378
Ok, I replaced the Transformer and now it pulls in and everything works. The power up and down still only works if the spindle is running, I don't know if its supposed to be like that or not, But I'm okay with that.
The DRO is still not working, I took the display off and plugged it into my TOAUTO DRO cord and the display works, So its a wiring issue, Here is how its wired the way it was when I got it.
Yellow is wire nutted to ground
Blue is wired into one of the 3 ph wires coming from converter
Brown is wired into another of the 3ph wires coming from converter
This does not make sense to me, 110 should be a Hot, A common, Which is also a ground and a Ground wire, So 2 grounds and a hot? Am I correct to say this?
