Ok, I have it running now, I found that The previous owner had wire nutted the wires together on the transformer without removing the ferrules, I believe they were in a DIN rail before, I clipped the ferruled ends off and wire nutted them back together, Then tried re-orienting the main wires coming in from the converter again, I got it to work now, However it will sometimes make the static converter start buzzing, When that happens, If I push the KM-1 contactor in manually it stops doing it then works fine. I am puzzled by this, But that doesn't take much, I am learning this stuff as I go with help from you guys!
I got the mill as a non working machine, But When I felt the main disconnect switch, It felt bad, It was real crunchy. So when I wired it up before replacing that switch, I would get nothing, After replacing the main power disconnect switch, The static converter would make the click when I turned on the breaker, So the original switch was bad. I am wondering now if that contactor is sticking making the converter buzz? If none of this makes sense to you, Don't be surprised, When it comes to this stuff, I don't know my Crapper from a hole in the ground, But I am learning.
Edit to add: There are no fuses on this machine, I checked that first, Because when I was having problems with the Enco lathe a couple months back, I had blown both of the old glass fuses.
