- Nov 25, 2015
- 8,301
wow, evapo rust at tractor supply, it was 17.99 last time I bought it, now 24.99... I really wonder if all this inflation isn't some companies just taking advantage of things. And it's becoming self feeding.
I went out and picked up 3 gal's of kerosene at $5.22 a gal to use to get the bulk of the dirt...
ebay.. if you can find a part that matches, buy it.Been busy for a few days and wanted to get back with what's been going on. I got in a bit of a hurry and decided to put my Apron back together to make room so I could tear down the gear box. I thought that two days was enough time for the paint to be tough enough to work with. It's been cold here and the shop cools down a little at night which means the paint takes longer to cure. I was trying to be really careful but while putting it back together the paint got a little soiled and left some marks in places. I may be able to touch it up a bit but if that don't work, I guess I'll just have to tear it down and start over.
I started on the gear box and right away I ran in to a small problem. A lock pin on one of the gear shafts would not come out. I think someone had tried to get it out and tried to drive it out the wrong way. I banged on it for a while and decided that it probably won't going to come out the easy way so I ground a flat on the collar in hopes to remove some of the burrs and be able to tell which end to drive out. On one side I could see where the pin was but on the other side there is no sign of the pin anywhere. I ground a little more and still no trace of the pin could be found so I guess I'll have to drill the pin out. The side I can see appears to be the big end, so it isn't coming out that way.
I guess now I'm wondering where the best place is to get parts like this. I called Grizzley the other day and waited on the phone for 45 minutes and still didn't get anyone on the phone. This is like everything else I try to fix I spend more time on the net trying to find the stuff needed than it takes to fix what I'm working on. I checked e-bay and I found one of those nuts for the tailstock and the guy wanted $30 for it plus $11.00 for shipping. I'm wondering now if I wouldn't be better off just parting this thing out rather than trying to go through the the trouble and time trying to find the few things that I need to replace. Is there any other place besides Grizzley and e-bay that may have parts for these things?
