Extreme Air Mail! Mailing Tube Rocket Project!
I imagine it would bond well on a high power rocket that uses a fiberglass body tube.
Your tenon and or filet idea is probably a good one regardless. How big of motor? I haven't fired off a model rocket in over 40 years so barely remember sizing.
It'll be a D12-3 for the first attempt. We'll see where it goes from there!
Really any 24mm motor should fit. They range from C11 to E30 (Estes).
Honestly after trying a launch on a D12, I may try a C11. I’ve never run a sim on that one yet.
The point of this build was not to attain max altitude but rather to make a successful launch of a vehicle at or near the maximum possible weight for a given engine. Based on simulations I believe my design is about there. It should make for a somewhat slow lift off and an interesting low altitude flight.
Of course I’m still pretty new in the hobby so it may all go belly up!
OK fins are made!
I had another slow day at work and had time to run to the hobby shop. A sheet of balsa 6" x 36" x 1/8" was only $5! I only used about 10" of it. The fin tenons will have to be trimmed to fit later, they are left long.
Here's the treatment I've been giving my rocket fins lately. I read about making a "fin press" in one of Apogee's newsletters. In the article the author used epoxy but I tried this polyurethane glue from Titebond and it gives me good results. It foams up to fill voids and maybe it even penetrates the grain a bit. It dries to a smooth hard shell when cured in the press.
The plastic is polypropylene or HDPE cutting mats from IKEA. $1.99 for two mats if I recall. They are mounted to a piece of 1x6 poplar.
I don a pair of nitrile gloves and the glue is spread on with a plastic Bondo spreader. The glue could've been a little heavier in the following pic but hopefully with clamping it'll even out over the surface.
Usually with smaller fins I'd just put a heavy object on the top piece of the press but for these fins I'll apply 6 heavy C clamps for 24 hours.
Tomorrow I'll do the other two fins and then figure out how to cut accurate slots in the body tube.
Looking great! I can't wait to see the altitude or lack thereof.
Robert
