- Oct 31, 2016
- 2,647
Welcome to the forum. What kind of lathe do you have? Most imperial lathes can cut metric threads with the right gears.
I find your original post confusing. It sounds like you are only measuring run out in the adapter and then surmising that there will be run out in the work. You need to measure something of a know OD to check for run out. Even if the work has run out to start with once you turn the work there won't be any run out in the turned part. For example 3 jaw chucks always have run out. They never hold the work concentric to the spindle of the lathe. Yet the work is always concentric to the lathe spindle after being turned.
Run out in the threads will not cause run out in the work held in the collet. The collet registers on the taper of the adapter. Not the threads for the collet nut. Look how loose the collet fits in the collet nut.
Tell us more about what you are making and how you intend to make it.
