- Jan 1, 2018
- 1,185
When I ran the tubing for my 3 head mini-split I found separate lines MUCH easier to run and bend than having the high pressure and low pressure copper lines bound together by the insulation.
This is the copper refrigerant line I went with. It also has a good bit more insulation on it than the bonded line sets.
ISO14-1-50 - Isoclima ISO14-1-50 - 1/4" Line Set w/ 1" Insulation x 50 ft. Refrigerant Line Set (Single Roll)
Isoclima ISO14-1-50 - 1/4" Line Set w/ 1" Insulation x 50 ft. Refrigerant Line Set (Single Roll) - 1/4" Line Set w/ 1" Insulation x 50 ft. Refrigerant Line Set (Single Roll)<br><br> <b>Product Features</b> <ul><li>Ideal for mini-split systems, unitary residential and heat pump installations...
www.supplyhouse.com
SupplyHouse.com - Plumbing, Heating & HVAC Supplies - SupplyHouse.com
SupplyHouse.com offers HVAC, PEX, radiant heat, hydronic heating and plumbing supplies. Shop now for great prices on PEX Tubing, thermostats, fittings & more.
www.supplyhouse.com
