- Oct 31, 2016
- 2,649
My new to me house only has a small electric wall heater, a small window ac unit and a wood stove. Talked with some local HVAC contractors about installing central heat and ac. Been told can't do it in my house because no way to get ducting to the bathroom and one bedroom and code requires every room in the house to have ducts running to it. I only want to heat and cool the living room/kitchen (332 sq ft), a bedroom (120 sq ft) and have a duct in the hall aimed towards the other bedroom and bathroom. In a previous home I installed central heat by myself. No ac in that house. No big deal to do. Rather simple actually. This house has to have ac.
My issue is the refrigerant lines will need to be either brazed or soldered at the air handler and at the evaporator. Brazing is out of the question for me to do myself. Soft solder or silver solder is probably doable. But what about using epoxy to join the fittings together. Searched online and didn't find anything about using epoxy to join hvac fittings together. Not even don't do it. Normal epoxy won't work because the lines can get over 200 degrees. What about high temp epoxy? You can buy epoxy that is good up to over 2000 degrees. Readily available high temp epoxies are good for up to 600 to 700 degrees.
Anybody have any knowledge about this.
I don't want to put in a mini split because I don't want the butt ugly unit hanging on a wall in my living room and it would not heat or cool the one bedroom I want heat and ac in.
