- Oct 13, 2014
- 7,085
Oh man I am so sorry to see this, thankfully no one was hurt.
If I was in that situation, I'd build a temporary but well constructed "gantry" out of wood or steel over the lathe, put a sling around the bed near the headstock and slowly lift it with a chain hoist.
Machinery Riggers.Understood. What type of company do I search for. Everyone says get the right people but give no examples.
That's a big "IF" If the joists/beams above are strong enough to bear the weight. Maybe, if the joists are say 2x10's and you run a temporary triple 2x12 beam crosswise resting 4 of them it could work. But if that's a garage with truss roof, the bottom chords are likely just 2x4's, which would not be nearly strong enough.Next, you might want to do like @pontiac428 and cut a hole in your ceiling, and hang a chain fall over the tie beam.
lift from inside the bed webbing using straps and add cribbing as you lift to prevent it from settling back on the lathe if things go wrong.
