- Feb 2, 2014
- 1,068
The ping sound is not normal and I corrected it after that video was shot. The fly weights were hitting on the inside of the flywheel making the ping sound.
I went back out to the shop to tidy things up and reconnect your ignition module.
I just can't leave things alone so I had to give it one more try.
It started on the second flip and ran for 14 minutes before it stopped. I then gave it one flip and it started up and ran for another 10 minutes before I shut it off. The highest temp I recorded was 117 degrees at the cylinder head.
Over the next few days I will be running the engine numerous times to make sure everything is good.
I have a feeling there is still a problem somewhere.
Ray
Ray
