- Feb 2, 2014
- 1,068
The plans are not very specific as far as the governor goes and does not explain how everything has to work together. I have found that when working with a set of plans they are more of a suggestion than a rule as to how to make it.
These are the four parts of my simple carburetor less the spring. I have used this design on four of my other models and they work fine.
And the carb assembled and installed on the engine.
I couldn't help myself since we are so close I just had to give it a try.
I taped a gas tank I had made for another engine onto the side of the box and installed a short hose to the carb. Put in some fuel and gave it a few spins.
I started to get some talking (firing) from the engine as I was adjusting the carb and timing. It even made a few sentences of 5 to 10 seconds long and I thought I was almost there but then for no apparent reason there was no compression. Tomorrow I will take the head off and see what is going on.
YES IT DOES RUN just not for very long.
Thanks for looking
Ray
Thanks for looking
Ray
