- Dec 8, 2013
- 2,651
They ought to only say "assembled in USA" like some products say,or something similar if only ground in USA.
They can call it "Made in USA" if more than a certain fraction of the value was added here.
When you consider how crudely a drill bit cuts, flexes, and bends in comparison to other cutting tools, having them undersize is a boon.
Thats why you ream to final size...from what I have been taught....Tim
I have many hundreds of drill bits. I have several older sets that were USA made, one older 115 pc. HF set that is complete and never been used (bought as backup but no longer trusted), the only other import set I have is a 29 pc black oxide coated fractional screw machine set that is actually OK. Most of my drills are purchased at garage and estate sales and from lots of tools found on Craigslist. I sharpen them myself, and know how to do it right. I use the old Craftsman jig which is just fine if you know how to use it and check each one by eye and on a drill point gauge. Bits over 3/4" I sharpen by hand, using a drill point gauge to check the progress. The old bits i buy need de-rusting, rolling on the surface plate for straightness, repairing the shanks, inspecting, gauging for size, sharpening, and oiling and labeling for storage -- but they are usually high quality drills that are worth the effort. Cheap drills are kept separate for less demanding tasks. Rehabbing drill bits is mindlessly boring but is also relaxing and satisfying. My pet peeve is that most drills I get have spun in the chuck and the shanks are buggered. Doesn't anybody know how to tighten, repair, or replace a chuck?
Looking for a nicer drill sharpener but have not yet found one at the right price/quality point and the one I have works...
My observation of TIN (titanium nitride) drills of lesser quality manufacturers (anything Asian) is that the coating hides and tries to prop very poor quality tool steel underneath; they are not much good for demanding work, such as drilling stainless and heat treated steels. I would stick with known brands of HSS cobalt steel or even ordinary USA made HSS tools.I bought a 115 piece tin coated set Grizzly last year on their president's special. I think it was $45. It's been a good set. There are a few that I used constantly and finally broke. When that happens I run down to Marshalls and by a 6 or 12 pack of US made bits to have on hand in sizes I frequently use. If I need accuracy my small reamer collection will increase by one.
Dave
