Good day everyone, I'm hoping some here can help me understand drill bits and how they are sold.
Documented below is my recent experience in case it might help someone else, also please note this it the first time I have ever bought a set that included anything except the standard fractional bits.
I recently purchased a 115 piece drill index, it was cheap so I assumed the quality wouldn't be great but hoped it would get me by for awhile. On inspection several things jumped out right away as I could not pivot all the trays to access the bits which it turns out was because only one tray on the "letter" side was attached to the pivot point, the next thing I found after getting it unbound and opened was the tray for A through K was inverted to the markings, ie. K was the smallest and A the largest bit in the tray.
Next one of the numbered bits stood out because it was shorter than its neighbors on either side, the number 5 hole was occupied by a clearly marked 13/64 bit, and almost none of the (smaller diameter) larger numbered bits were within a thousandth of what they were supposed to be and several were the same diameter and some were ground so poorly the chisel point was off center by 1/3 of the diameter or worse.
While waiting for a reply from the vendor which sold me this set I bit the bullet and purchased a brand name USA set, (at six times the cost) which is a vast improvement, however I still found a few bits (four in the numbered set) that were a thousandths or more different than what they were supposed to be. To be fair I must admit I have always used USA manufactured bits and have always taken the diameter on faith and never checked them with a mic.
So the question -
1. Is this normal? (example the 1/4" bit has a diameter of .2485) or have I managed to get a sub standard USA manufactured set as well?
2. If you really need an accurate hole you ream it, so is a bit within a thou or two common and acceptable?
Thanks
So the question -
Thanks
