- Sep 24, 2020
- 1,907
No need for VFD, it turns a basket slowly so the case gets cleaned.Correct capacitor, but unlikely to be the capacitor they do not go and if they did would most likely go open. If you sign up for Zoro email notifications with a different account they normally send you a 15% off. Alternative is a 3 phase gear motor with a cheap VFD if you wanted to adjust the speed.
One add to above, it is possible that the gearbox failed and is jammed which would account for the high current.
Not everything needs a 3 ph VFD............
