I've got a relay on my parts washer and it's just started tripping. Runs for about 3 minutes them trips, comes back on in about a minute and runs for a couple then trips again.
WOW that is a lot of power for a parts washer, must be big.
I would start by checking the amp draws to see if something is drawing to much and causing the relay to trip like it is supposed to.
A bi metal relay will not wear out when it is not doing anything. if it had never been tripping before then it was not moving so there should be nothing worn.
Can you measure how many amps the machine is currently pulling? Bi metal can wear out if they are tripping all the time. I know we have had to replace them after having motor problems.
Easiest way is with a clamp-on ampmeter- can you borrow one? Oh I see your post, yes the HF unit should work
You might check for poor or loose connections to the relay- that might cause nuisance trips also
-Mark
