DIY OD Grinder fixture, For the surface grinder- maybe
What's the purpose of the paper Jeff?
It lowers the ability to slip. The paper adds a little bite (friction). metal to metal sometimes has the slide potential. Nice idea Jeff.
That makes sense. Like putting plywood on a pallet jack before setting a machine on it.
I’m going to bore it.
Stay tuned for my design. Don’t point and giggle when you see it. Be gentle.
Oh I didn’t look closely enough. I thought you were making an ID groove, so you might use a rotary table with a key seat cutter or a single point cutter in the boring head. With the piece fixed on the mill table, I guess you can bore and press in an insert to leave a glove gap?
This is not adequate but this is what I have. I don’t do anything like cad or fusion etc.
I’m still not sure what to do about the oring or sealing method.
I did notice there is a groove in the spindle. I can make it work but I can’t visualize it until I cut the bore fir the bushings.
Then I can put it together, figure out my next move before I machine the brass.
I will have a method to add lubrication and it will be shielded from grit.
One step at a time.
The bushing will be .625 wide and .200” thick. I am going to allow .001” clearance between the spindle and the bushings. As it is now there is probably.005”. Way too much!
I do have the bore coplanar with the base and both ends standing on the surface plate are within .001”. In other words, I’ve been careful with each step. I’m really trying to not screw it up.
That was easy.
Came out as expected. Surprise :)
The finish is great, a little chatter but not an issue at all.
I have some planning to do for the next step.
