H
Hukshawn
Forum Guest
Register Today
Never under estimate the power of operator error!!
Ok tozguy, I need you to tell me what you want to see... I cannot see anything wrong in here and I have no idea what I'm looking for
gear noise between one lever change gear and the numbered gear cluster. I spent nearly an hour trying to figure out why there's noise and one tooth of mild stiffness. I gave up and assumed it was just a bit of wear or that's just the nature of this beast.
However, I still don't know how to fix this.
Do you still believe the lead screw is wrong? which could indicate the inch gear train might be correct?
And coupled with the 32t gear? how confident are you a 54t gear would correct this? that would be cheaper to have made than a 34t and a lead screw...
