that looks pretty good, you must have a mill?
I don't wish I did. I have to do things with a bandsaw, and a lathe a lot, hack saws and files, sanders, drill press,etc.
I would like to come across a stout bench top unit (mill) at the right price some day.
I don't know, I have not heard back from that guy yet, maybe he is working.
I have read some threads where guys say you really don't need a drop cylinder.
And they are controlling the drop rate with moveable weights and counterweights,
And some guys have made there own out of air cylinders and screen door closers.
But it involves adding valves and adding oil, I don't want to get in to all of that.
I might see how it works without it.
I'd bet even a rubber bungee cord stretched from above, with the right tension would control the feed.
Sort of cold right now, though, so the shop is not very inviting .
I might mess around with it in the laundry area, as it has a heater and a door to close it off.
Had to for when it gets cold, this Micky mouse rental garage apartment I live in, the pipes will free up,
and the washer water pump will freeze up if it gets below a certain temperature.
Landlord don't do Jack around here, unless something is real bad.
I end up fixing most everything, just bill him for parts.
He should have 50 tenants like me.
I got my arbor press back there, and will but the bandsaw back there, I have to come up with a stand for it.
