- Mar 14, 2013
- 736
it is a 108.22921
i use vacuum cleaner belts as tires on a different type of craftsman bandsaw. i have changed alot of tires on all different types of bandsaws and never had to glue them. Usually the tires are so tight they have to be put in almost boiling hot water for a while to heat them up enough to stretch them on.
Yeah, there too dear at sears, I only paid $50.00 for the bandsaw(s) (one is not complete)Interesting .. The tires for this bandsaw are $25 each + shipping from Sears. Not very cost effective in my books.
Your idea seems more promising ..
There is a local vacuum shop that has a great parts counter.
I will drop by and post the results.
Tks !
I was doing a bit of research . yours looks like it maybe an Atlas made version.
I copied this note from some where.
" That metal-cutting bandsaw was in the 1969 Sears Craftsman tool catalog, No. 99 AT 22922N2 (with motor) for $149.95. The blade is 1/2" x 60" x .020" and is welded backwards to every other bandsaw I have seen. The saw looks a lot like the Taiwan pivoting cutoff saws that became common in the late 1970's, but is made backwards.
Yes, Thank You,My cutoff saw doesn't have tires, and it works just fine.
Mr breezeet1
"Do I have to turn the blade inside out?
Where are you getting your blades, or do you have them made up?
Sorry if you said already. "
I got a fairly new blade with mine. lucky score..
These are left handed saws ( kind of a joke with a friend and I )
If I needed a new blade I would be sure to order it for my application .
The saw cuts right to left as most newer saws cut left to right.
I disassembled my saw today, every thing looks to be in good condition.
Some of the shafts need to be cleaned from paint and grease. All the bushings look good too.
The beveled drive gear is nylon ! It has some wear but no concern for a 45+ year old machine.
The only other issue is the drop cylinder leaks a little ( maybe it needs a new seal ).
I also inspected the main castings for any signs of cracks and found nothing.
I buy most of my Tool stuff from Tegs Tools in Hamilton On.
www.tegstools.com
