It’s alive!!!
I have spent the last few evenings mounting the motors, wiring her up, tweaking the settings and had to rig up the small z motor to gear drive as it was under powered for direct drive. Jim had said he figured it would be.
I housed the BOB and drivers in an old Hayes 14000 baud modem(remember those). I wired it with disconnects so I could use this controller on other devices.
I did this project mainly as a learning exercise and let me say it certainly has been. Tweaking the settings was a challenge. It kept telling me axis exceeds the machine limits. Since I don’t have hard stops wired in I had set soft limits to the machine. I eventually just changed that to higher numbers and the problems went away.
I still plan on tweaking it some more with paint, welding end pieces on the frame ends and perhaps a motor upgrade or redesign on the Z axis. I may throw on some limit switches as well. I still need to master G code since I have decided my next project will be a delta robot.
My goal was to do this cheap. I figure it cost me $65 out of pocket. Here were my costs.
Frame materials =$ 0 scrapped treadmill
Linear rails for x and y= $18 for 10 foot ¾ schedule 40 and 10’ 3/8 all thread
BOB and 3 motor controllers = $29
Parallel cables $10 for 3 one was bad. Only used one of them
Misc screws and nuts, Welding rod, sand paper, hose clamps, propane for furnace <$15
Motors and Power supply= $0 would have been around $60 if bought on ebay
Laptop was one we bought for Daughter when she first went to college 12 years ago. Has been sitting on a shelf unused for at least 7 years. I think we paid around $1200 back then. Could probably find similar specs for <$100 today.
I made various mounts and bearing holders from recycled aluminum.
And I burned a whole lot of electricity between all the testing, internet research, welding and time in shop.
Anyway thanks for the initial advice it got me going in the correct direction
Controller and cut.
