- Dec 27, 2013
- 124
this has been a very good thread with a range of directions in the discussion. Hopefully back to the why and end mill holder instead of some collet system. I may be beating a dead horse here.
My machinist-for-a-living son tells me they will use a double set screw end mill holder for the higher loads, both feeds and speeds and more likely on larger diameter cutters. They have also used the heat shrink versions as well (don't know which they like better). He is primarily speaking of working some cast form of 4340. Their experience is, yes, it is easier to pull the end mill out of a collet than an end mill holder. This is primarily CAT50 tooling on machining centers. Here we are talking about something that would certainly not be hobbyist and not too likely some something non-CNC machining center. They will also run will flood coolant and at full speed and feed, maybe more.
As a hobbyist, needing less tooling (and it being better) is attractive as I consider adding ER40, ER32, etc for the lathe and mill and dividing head and so on. Since I don't get paid for doing a lot them fast and are running at full entitlement (most of the time) on the speed or feed, and not spinning an end mill larger than 3/4 inch, the R8 seems to be OK. I can also go inside, get a drink of water, come back and reduce the DOC or feed. I also see a case for capability in being able to remove from chuck and then return it with near zero loss of center.
