mikey, do you have any measurements comparing the accuracy of the end mill holders you used and your ER collets? Did the end mill holders disappoint you in any other way than accuracy? I ask because in my limited experience with entry level Weldon holders and ER collets, the holders are more convenient, less expensive and perfectly adequate for what I do. No end mill ever came loose in the holder. But I might be missing something.
More money would probably get me more accuracy with either type. Of course the ER system is more versatile and has other uses so it would make sense to invest in high quality ER parts.
Morning, Mike. Yeah, for all of us, tool holder choice is a balance between what is adequate for our purpose and the cost we're willing to pay. I'll give you my rationale for what it's worth.
When I first started playing machinist, I began with a Sherline mill and used end mill holders. The mill was accurate; spindle run out was and still is about a tenth (I have ABEC 3 bearings in there) but the end mill holders ran out a LOT more and I had end mills dropping and digging into the work on occasion. I don't have them anymore so I don't have numbers for you but I remember thinking it was so bad that I jumped to a Beall ER32 chuck as soon as it came on the market. That is when I learned about how big a difference an ER system can make.
My Beall chuck runs out about 0.0001" inside the taper, no joke. This is pretty good for something that screws onto a spindle, and it helps that the spindle itself is accurate. I began using the collets that came with the chuck; these are imports I'm sure, but they are good imports and I noticed I could cut deeper with a better finish than with end mill holders. Here, I'm talking about a 3/8" depth of cut with a 3/8" roughing end mill in aluminum using a mill that weighs maybe 45#. No way could I do that with end mill holders. I noticed that finish end mills also seemed to finish better and lasted longer and that really got my attention. I stumbled onto a white paper from Techniks that pointed out that for every 0.0001" of run out, end mill life declines by 10%. They also pointed out that ER chucks reduce vibration better than any other system I could hope to afford. These two things - tool life and vibration reduction - really made me realize why an ER chuck worked so well on my little mill. It also made it clear that good collets are required so I bought a set of Techniks ER32 collets and ran tests. In my Beall chuck the import collets have about 0.0004" TIR max, if I recall correctly; the Techniks are half that at about 0.0002 or less in that chuck. I also found that the Beall nut is really good but a Rego-Fix nut is better; it actually cut down TIR with the better collets. That sold me on the ER system - more accurate, no slippage, less vibration, improved cutting performance and better tool life. This is all on a little Sherline mill but I didn't forget.
Then my neighbor gave me an RF-31, for free! It came with some import R8 collets and a few import end mill holders. He only used the mill to drill bowling balls and never maintained the mill so the first thing I did was evaluate the spindle. It had something like 0.004-0.006" TIR! Yeah, really bad. I set out to rebuild the spindle and got it down to just under 0.0001" TIR, which I think is pretty good for an import mill. I don't recall the numbers but the run out with the end mill holders, even in an accurate spindle, was pretty bad. The second or third time I used one of those end mill holders the end mill dropped and snapped a Niagara Cutter end mill and that was it; I passed them on to a friend and never looked back. I figured that I had a decent spindle on this mill and I was going to invest in good tooling for it.
I bought a set of Crawford R8 collets. Crawford makes the collets for Royal so they're pretty good, in the range of 0.0002" TIR in my machine. Then I bought an ETM ER40 chuck that came with collets and nut and these run out 0.0001-0.0002" so they are pretty good but the chuck is huge and limited access on some of my projects so I wanted a smaller chuck. Since I already had Techniks ER32 collets, getting a decent ER32 chuck made sense. As I looked over the field, the TTS system came to my attention and to make this novel a bit shorter, I decided to go with that system. I bought their ER32 chuck and later bought the ER20 chuck, too. The TTS chucks are fairly good. Not as accurate as a high end chuck but I can hold 0.0002-0.0003" TIR with a Techniks collet. You have to use their nuts on their chucks, which is a bummer because I think I could get better run out with a better nut but so far this system has worked okay for me.
So, now I run all my non-critical stuff like fly cutters in import R8 collets and more accurate big cutters in my Crawford R8 collets. For all end mills I use an ER chuck. If I am doing heavy work, I try to use the ER40 ETM chuck. For average cuts I use the ER32 and when I do finer detailed work that requires me to get close or if I'm using smaller end mills like 1/4" or smaller cutters, I use the ER20.
That's my story and I'm sticking to it. I put a lot of thought into choosing this system because I won't lie to you, it was expensive, but I'm happy with my choices.
