- Nov 15, 2020
- 139
Looking for a Clausing 8520 Mill Power Feed. Model 8635.
Could you send me or post on your imgur photo page some pictures and comments on installing your power feed. What exact model did you use? The original Clausing was mounted on the left, but all retro fits (usually Bridgeport's or clones) are mounted on the right side. Thanks.I used a Chinese power feed, it was an easy install and gas worked well for me
The chinese power feed drives are functional and affordable. Servo (the power feed drive brand, not the motor type) is a lot smoother and finer at roughly 2x the cost, and is one of the better power feed drives out there. Because of the packaging, I'd stick to storebought options. This is one of those areas where I might not want the savings of buying used against all the unseen stuff that can go wrong invisible to the buyer. In general, Servo drives are expected to serve 20 years or more in a commercial shop environment. I ran a china drive for 3 years as a hobbyist, and it worked, but it's apples and oranges. Also, every part is available by number still from Servo or their distributors.That certainly seems like the route most people take...
I am not sure I have a bunch of pics. I didn't put any on imgur, I'll see what I can find.Could you send me or post on your imgur photo page some pictures and comments on installing your power feed. What exact model did you use? The original Clausing was mounted on the left, but all retro fits (usually Bridgeport's or clones) are mounted on the right side. Thanks.
Not 2x the cost, 3x at least.The chinese power feed drives are functional and affordable. Servo (the power feed drive brand, not the motor type) is a lot smoother and finer at roughly 2x the cost, and is one of the better power feed drives out there. Because of the packaging, I'd stick to storebought options. This is one of those areas where I might not want the savings of buying used against all the unseen stuff that can go wrong invisible to the buyer. In general, Servo drives are expected to serve 20 years or more in a commercial shop environment. I ran a china drive for 3 years as a hobbyist, and it worked, but it's apples and oranges. Also, every part is available by number still from Servo or their distributors.
Thank you. I am trying to find a power feed for the 8530 version, on which the right manual x axis feed was a two speed set-up. By moving the handle in or out, a more rapid manual transverse could be done. Therefore, Clausing made a power feed for the left end, which are rare and have reliability issues any way.and the next post in the threadPOTD- PROJECT OF THE DAY: What Did You Make In Your Shop Today?
Finished up a cooker for a guy that wanted different design elements. Removable drum. Racks high and low for wood/charcoal. Wants a stand made later to mount cooker on. Gonna be a little heavy with extra racks inside.www.hobby-machinist.com
post 982
Took it as far as I can here… 1/4”-20 threads done… Hex bolts just to test, need to get correct ones… 5/16” hole made for 3/8 tapwww.hobby-machinist.comPOTD- PROJECT OF THE DAY: What Did You Make In Your Shop Today?
Suport tail end with adjustable parallel?www.hobby-machinist.com
Another bucket emptied on the garage floor . Pic to come . Lots of good lathe tools etc . in there . What I'm planning .......take them down the basement and arrange everything together that goes together , then sell the piles as lots . This next bucket will be a nut buster ! :eek: Making...www.hobby-machinist.com
If I find others, I'll post it.
