- Oct 11, 2016
- 3,860
HEHEHE I have my wife out hunting a 3rd job so give a few
always happy to oblige, sorta...
Make sure you have enough tooling for your toolpost - as delivered - you can turn a chip in steel. Then before you spend a lot of money, make a bunch of shavings. Usually the first purchase is a decent tailstock drill chuck.
Really the only way to know what you need is to start a project, expecting to have delays for tooling. It is a bit if an extravagance to buy tooling in anticipation that you might just use it. But we all fall for that temptation, sooner or later!
However a safe bet is tooling to bore a hole, so a boring bar in say 1/2" to start, using insert tooling. After nearly 40 years, this last year I finally bought a 3/4" WNMG boring bar! All these years I've been using 1/2" shank boring bars, home made for a variety of holesizes from 1/4" up.
-- Don't be bullied into spending hundreds of dollars on QCTP and accessories. If it comes with one and a couple, of holders, fine, If you have a 4-way, you can use that until you need one. Make chips first. Develop lathes skills first. Understand the mechanics of tool height first. Then a QCTP will make a big difference, and you will already have tooling that will need one.
