- Oct 11, 2016
- 3,860
I've been looking for great tutorials for our 'beginner tutorials' section. PM me if you find one also.Do you know of any good tutorials on checking the head stock and tail stock alignment that you would be willing to point me to?
Here's how I've done it for over 40 years:
When you are setting up the lathe you need to first get the ways *approximately* in a single plane. I call this alignment - but a more common term is leveling. That is because the easiest way to get the ways ready for setting up the lathe is to use a machinist's level. But any level that is sensitive to .005 (or even .010) per foot will do.
You can then align the headstock. That is done by turning a short piece of easily cut material - aluminum, soft steel, whatever you have, that is 1" in diameter or greater. You check that the *headstock only* is cutting a perfect cylinder, accurate to you best measuring device.
You then need to align your tailstock. I use a 'dial test indicator' to do this. but you are free to explore alternatives. I chuck my DTI in the 3 jaw chuck. Then I position the carriage, DTI and tailstock barrel so that I can sweep the inside of the tailstock taper with the tailstock barrel just contacting the tool post. My DTI holder is long enough to do this, but you might have to fashion an extension.
Now comes the magic. Once you have proven that the retracted barrel of the tailstock is on centre, you then crank out the barrel, which is held by the tool post. This causes the tailstock to move outwards from the chuck and DTI. You then adjust the tailstock so it reads true again. You might have to go back and forth a few times, depending on the design of your tail stock.
Then and only then, can you do the 2 collar test, which gets you to under tenths of a thousand of an inch on tapers. I've never need to do this step.
