- Jun 12, 2014
- 4,776
Electrolytic capacitors have a finite life span (usually 7-10 years), even if not used. The live span is decreased with both heat and operating them near their maximum voltage ratings. The specification (measured capacitance) on electrolytic capacitors can be very wide, so something like -20 to +50% of their rated uF value. Using the standard multi-meter to check capacitor value is of minimal value, unless the capacitor is completely dead. Replacing an electrolytic you do not need the exact same uF value, anything close is fine and getting something rated for the same or higher voltage is fine, they should be 105C or higher temperature rated. Newer capacitors are significantly better than those used in past years, so given the age of the drive you are best replacing them. Most electrolytics are polar as others have indicated, there ia a + and - end, the - is connected to the shell, the plus you can see some insulation between it and the outer shell. There are also non-polar electrolytic capacitorss, that do not have a polarity orientation. Newer diodes usually work or fail, so if they check OK I would just leave them.
You might consider buying the replacements parts through an online vendor like Mouser Electronics, a wider selection, fresh stock and probably cheaper even with shipping.
