- Feb 2, 2013
- 3,639
my mistake, the 1hp motor pictured https://www.machinerypartsdepot.com/product/SP23PHThat particular package was 1 HP (1J stock BP) to a 3-phase 1.5HP Baldor. But yes, still a little expensive. When you say "punch out the pulley", what do you mean? I have a vari-speed machine and the drive aspect of the motor is the var-discs and they have bushings. So if I were to buy a different motor with a larger shaft, I understand boring out the internal diameter of the vari-disc and cutting a new keyway, but I'm not quite sure how the bushings would be solved. Just find some suitable bushings and install them in the vari-discs?
requires boring the pulley to 7/8" from 3/4"
that's for a 1J head, the motor won't work on a 2J , i didn't realize you had a 2J
