- Feb 14, 2020
- 166
Seems if the actual motor does not match the nameplate, I would guess it had been rewired by a motor shop in the past.
It does not make sense that the VFD drives the grinder but not this motor. All you did was paint it? Just the exterior, and did not split the bell housing off like you have for the photos? Have you tried running the motor with without connecting the shaft to the machine?
Yes, this is the first time I've pulled it apart. I have not tried running the motor with the shaft free of the machine. Are you thinking maybe the machine is frozen and not allowing the motor to spin up? I don't think that's the case. I can freely spin the spindle in gear and out of gear. The motor did spin, albeit very slowly in the video posted early in this thread. I guess pulling it and testing it on the bench is the only way to truly know that there isn't a problem in the bull gear/etc. And I suppose I'll probably need to take it to a motor shop to get them to rewind it or at least test it to make sure I'm not just a moron, so it has to come out anyways. I'll give it a shot tomorrow.
